Wow!
Over the years, PoolForum members have often reported bogus recommendations from pool stores, but your case is exceptional. Usually, ignorance is part of the problem, but your pool guys sound like they are deliberately dishonest. I think you should stay well away.
OK. Do this:
1. Go get a cheapo OTO / phenol red kit from Walmart. (If they have the HTH 6-way, get that kit instead.)
2. Test your pool, and report results here: http://pool9.net/pf-hist-form/
3. Assuming that your pool is NOT green, begin dosing with 1 gallon of PLAIN 8% household bleach EACH evening. (Walmart store-brand is fine; avoid Clorox brand since they are not selling so many 'flavors' and it's easy to mistakenly buy something other than PLAIN bleach.)
4. Test your pool each AM -- chlorine levels should be dark yellow (> 3 ppm). PH should be between 7 and 8. (Your current pH is FINE!)
5. Order a K2006 kit and a bottle of Aqua-Check SALT strips (not the test strips you have) => http://pool9.net/tk/
6. Fill out the EQUIPMENT form: http://pool9.net/pf-equip-form/
7. When you post your first test results, ALSO post a list of all the chemicals used in the last 2 weeks.
Good luck!
