Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    Default Re: Clear, but no chlorine???
    Did your closing method work?
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    Not sure: My pool opened this spring w/ very clear water and so in that respect, yes….but that was pre-BBB thinking. Now that I know a bit more about my pool's chemistry and the FC/CYA connection, I know not to shock with the bags of powder so I'll use enough bleach to reach FC=30. I also wanted to find out if my high CYA needs to be accounted for in some way. I'm not sure what the CYA was last year or this spring because the pool guy told me not to worry about it- which I now know was a huge mistake.
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    Um, I don't see what the problem is. You threw in bags of...cal-hypo or di-chlor and it protected your pool over the winter. Did you test your water in the spring? If the #s were acceptable why change?
    BBB is a way of thinking more than a set of rigid rules. There's a time and a place for Di-Chlor, Cal-Hypo and Tri-Chlor, as well as bleach.
    Carl, you may not have enough of her thread to know but her CYA is high and her fill water is high in CH. So, bleach is probably the better choice for her.
    BigDave's Avatar
    @CarlD: mary jo's pool's CYA is 150 and the CH is near 700.
    @mary jo: What CarlD seems to be getting around to is:"If shocking the pool worked in the past, might as well shock the pool now" which is your plan. Watermom's suggestion of using polyquat 60% is probably a good idea too. Are you going to have the pool guys winterize the equipment again this year or do you plan to do it yourself?
    Well, I would agree with that. But it doesn't indicate a major change in strategy, merely replacing problematic chlorine sources with our fav...bleach.
    My own closing routine is, of course, get everything (in the chemistry) clean and balanced, wait till the water temp drops to 60 (65 max), raise FC to shock level. Add 1 qt 60% poly, wait 48 hours, then test and raise FC to shock level again...then close.
    Aug 2014
    Batavia, IL
    Sounds like a plan, thanks, got it.
    @BigDave: I'll definitely have the pool guys winterize the pool- it's something I don't want to tackle at this point.
    I promised the kids 3 more weeks of swimming so it should be plenty cold when closing time comes around. thanks
    Jul 2013
    Northern Illinois
    Hey. You mentioned that you were planning on retesting CYA. Did you? Just curious
