@the pool store ----- welcome to the Pool Forum. But, we typically don't advise adding Foam Down and floc is only as a last resort. Since you are 'in the biz,' you may find that our methods are not what you may consider the norm for maintaining a pool. We would respectfully ask that you read and enjoy getting familiar with the forum but for now, please refrain from giving chemistry advice. We usually find it best if our 'pool guys' initially take the time to just get to know what we are all about instead of answering posts as soon as they join. We hope you understand.
@Apatton --- I want you to test your sand filter to see if it is working properly by adding a handful of DE to the skimmer while the pump is running and watch the returns to see if white powder is blowing back into the pool. More about this can be found here:> http://pool9.net/de-test/
Report back the results of this test. Also, tell us what kind of test kit you are using to test with and exactly what all you have added to the pool -- meaning ingredients, please. Your foaming is definitely from the algaecide. This is one of the main reasons why the only algaecide we recommend is 60% polyquat. Most others do little to help and cause lots of issues that are difficult to clean up.
Welcome to the Pool Forum, by the way!
(Until your registration is completed, you won't be able to follow links nor see the rest of the forum while you are logged in. So, copy the link and paste it into a browser window after you first log out.)
