Re: Very Cloudy/Foaming issues
A TA of 900 meant you had to put 90 drops of the R-0009 in to get the sample to go from green to red. Are you sure that's what you did?
Review of TA test
1) Fill tube to 25ml mark
2) Add 2 drops of R-0007 and swirl
3) Add 5 drops of R-0008 and swirl--sample should turn green.
4) Add 1 drop of R-0009 and swirl
5) Repeat #4, counting drops, until sample turns red and stays red.
6) Multiply # of drops added by 10--that is your TA number.
CH:
2) Add 20 drops of R-0010, and swirl
3) Add 5 drops of R-0011, and swirl. Sample should turn red or pinkish red.
4) Add 1 drop of R-0012 and swirl
5) Repeat #4, counting drops, until sample turns blue.
6) Multiply # of drops added by 10--that is your CH number.
Hope this helps.
I accidentally added a 0 to my TA figures yesterday. Haven't been getting much sleep due to the newborn, my bad...
FC - .4
CC - 1.2
TA - 100
CH - 500
pH - 7.0
Question about the Calcium Hardness...when I take the test, it indicates that my color will turn red after adding the R 0011. Mine keeps turning purple; like royal purple. I went ahead and continued adding drops until it turned blue and it took 25. That seemed excessive, especially considering I did the 10ml test.
I purchased an additional chlorine floater and some liquid chlorine to help boost my chlorine levels, will be adding that to the pool here in a moment.
Um, you're still doing the CH test wrong.
1) You MUST use the 25 ml line. It's the FAS-DPD test that you do to the 10ml line
2) Not sure what purple means...you may have no CH, but I won't swear to it.
3) If you added 25 drops of R-0012, that means you have CH of 250, not 500. But if you did it with a 10ml sample of water, I don't know WHAT the heck it means!
4) On your FAS-DPD test (FC/CC) use the 10ml line and each drop counts for .5, not .2. It's good enough.
It says that if high CH is anticipated, to use 10, and multiply drops by 25. I skipped it the first time since it was purple, but decided to do it this time...eventually turned blue with 25 drops which is actually 625 apologies
@CarlD: The K-2006 has instructions for a 10ml CH test in the lid.
@Apatton: CH of 625 is quite high. Do you fill with very hard water or was it something else?
I suppose my task today will be to test my hose water. Will report back with findings this evening.
Thanks BD.
Yeah 625 is super-high. Ben has a way of reducing it...I think it involves (counter-intuitively) putting lots of Cal-Hypo in the skimmer.
