1. Check the sand, as above, if possible.
2. Do NOT cycle your pump on and off -- disable your timer for now.
Instead, run it continuously till EITHER the water is clear OR the pressure has risen at least 6 pounds over the clean pressure. At that point, BACKWASH, then RINSE, before returning the multiport valve to FILTER.
