Re: Mustard Algae
Sorry, but if your CYA is 60 and your FC is 0, you are BEGGING for an algae bloom--and clearly have one. I would immediately put 7 jugs of 8.25% bleach (if it comes in 121 oz bottles) in your pool and get your FC up to 20. You need to shock your pool to at least 20 and keep it there til it is clear. The ONLY thing raising your pH will do is make it harder for the chlorine to do its job.
Given your numbers and description, the prescription is straight forward.
