Results 1 to 10 of 20
Thread: Mustard Algae
    Straightleg Guest
    Default Re: Mustard Algae
    Quote Originally Posted by Straightleg View Post
    fc 0
    cc 5
    Cya 60
    ph 7.4
    ta 120
    numbers seem good to me
    Have not done anything all summer but add 1/2 gallon (bleach) or alittle less each day.
    Only change recent was dropped my ph some
    Water still clear, and we have had a hot spell lately
    SL
    Fixed it:
    I typed wrong
    My fc is 5
    and my cc is o
    Jul 2013
    Northern Illinois
    Here's a link to your old posts http://www.poolforum.com/pf2/search.php?searchid=48573
    FC of 5 is too low for your CYA level anyway. CarlD will give you details
    Straightleg Guest
    Quote Originally Posted by FormerBromineUser View Post
    I cant get in to that link. I am locked out for some reason.
    My book in the k-2006 says ideal numbers. I am at every one. They say don't let your CYA soar up, so I have been careful with that. Watermom told me to keep it between fc 3-6. I have done that all summer.
    So now that you say this I am at a loss
    SL
    OK.
    Here's what I think happened: Your pH went in to the 8s, effectively shutting down most of your chlorine's ability to perform. (Somewhere we have a table or formula on that).
    That allowed algae to form. The answer is STILL to take your FC up to 20ppm (using 5 121oz jugs of 8.25% bleach, instead of 7).
    The only other possibility is that something else unrelated to chlorination is going on and it's not algae. But I don't think so.
    Straightleg Guest
    OK.
    Carl My ph has been 7.8 - 8.2 all summer, perfect water clarity. No algae
    Algae showed up 2 days ago
    I understand to get rid of the algae, I have to pour bleach on it to take my fc up.
    I will shock and clean the pool
    Then try a 8 to maintain it
    Jul 2013
    Northern Illinois
    With a CYA of 50, you want to try and keep your chlorine between 3-6 all the time. Here is what to do. Each evening, test the chlorine. Add enough bleach to take your chlorine back up to 6ppm. The next evening, if you find that your chlorine has dipped below 3ppm, take it up to 7ppm when you dose with bleach. The goal is to find out how high you need to take it so that it never drops below the minimum by the next evening. You will soon learn your pool's pattern.
    In case you need the Best Guess Chart again, it is here: http://pool9.net/cl-cya/
    I think this is the post to which you were referring. Your CYA is now 60 so you need to bump up WaterMom's original minimum recommendation for maintenance.
    HOWEVER, you now have algae. CarlD will advise you what to do but in the meantime, reread the Best Guess chart linked above.
    Sorry, Carl. We posted at the same time....
    Do your pool walls and floor feel slippery at all? Any chance that it is dirt/pollen/etc?
    Go ahead and take your chlorine up to 20ppm as Carl suggested above and while the chlorine is high, brush the pool.
    You don't want to keep your pH at 8ppm. Honestly, that is not the thing that will keep you algae free.
    Straightleg Guest
    Maybe it is pollen. Everyone has been sneezing lately
    When I say 8, I mean my fc...instead of 5...that ok
    Ok. I thought you meant pH of 8. My bad.
    If everyone is sneezing, I bet it is pollen. I just did a google search for 'pollen counts southern ohio' and found a page on the Weather Channel's website that lists it for various cities in the state. I didn't know what city you were in so I just put Cincinnati in and it said moderate to high.
    You can try it. Here is the link. http://www.weather.com/outlook/healt...drilldown/ohio
    Then, just click on the first letter of your city's name and you'll be able to find the pollen forecast for your area.
    But, having said that, still feel the floor the next time you are in the pool and see if you note any slipperiness.
    Hope this helps.
