It's not the time stamping on the posts that is important but the time you tested along with the results that we need to see. Being able to see the change from sundown to sunup is particularly telling when trying to diagnose what is going on in a pool with chlorine demand. As Ben noted in an earlier post, losing chlorine during the day could mean that your CYA is low. But, losing chlorine overnight when you take sunlight out of the equation, tells us that something is going on in your water.
Once you get past this chlorine demand issue, it is not necessary to test in the evening AND in the morning. At that point, testing just in the evening is enough. In fact, once everything gets stable and you better learn your pool's behavior, you may even be able to go to testing every other day. But, not just yet.
You do need to run the pump 24/7 right now. When you aren't fighting something in the water, the time of day that you have the pump on is not as critical. But, it is always best to test and add chemicals (especially chlorine) in the evening. The only exception to this is if your chlorine is too low during the day. In that case, you wouldn't want to wait until evening to bring it up.
