Page 3 of 16 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 155
Thread: Test results on new pool in Tucson
  1. #21
    Wilco's Avatar
    Wilco is offline Registered+ Thread Analyst Wilco 0
    Aug 2014
    Tucson
    Default Re: Test results on new pool in Tucson
    Pool is 32' x 13', sort of curved rectangle/trapezoid. 3' shallow to 10' deep. 18000 gallon I think with 500 gallon spa attached.
  2. #22
    Jul 2013
    Northern Illinois
    What is your K2006 CYA reading? If 100, your actual CYA may be higher. If 100, try a dilution test to determine your actual level. Mix 1/2 cup distilled water with 1/2 cup pool water, and run the CYA test again. Multiply the result x2. Post your results, please.
  3. #23
    Wilco's Avatar
    Aug 2014
    Tucson
    The cya tests between 90 and 110, given how the drop test is a little fuzzy
  4. #24
    Quote Originally Posted by Wilco View Post
    Yes I used the Taylor kit for test.
    *Which* Taylor kit?
    If you have a DPD color match (K2005, etc) those are USELESS for diagnosing "no chlorine" problems. If you have a K2006, do the overnight bleach test, but test with BOTH the K2006 *and* an OTO drops kit. If you do NOT have the K2006 (or K1515) use only the OTO kit.
    But . . . use an OTO kit no matter what!
  5. #25
    Wilco's Avatar
    Aug 2014
    Tucson
    I have the 2006, I don't have an oto kit. Sounds like it's better for routine cl testing/management.?
  6. #26
    An OTO/Phenol Red kit (yellow and red drops) is useful for quick daily checks. It is what I use most days and then use the K2006 once a week or so. An exception is of course, if I have need to shock the pool and need to be able to test higher than 5ppm of chlorine. In that case, the K2006 is needed.
  7. #27
    OTO is not super accurate, but it covers the range from 0 - 50 ppm, and it's pretty much goof proof. The FAS-DPD test covers the same range, but it *can* be screwed up. The DPD color match (K2005) covers the range from 0 - 5 ppm, (0 - 10 ppm claimed, but few people can read the difference between a 5 ppm red and a 10 ppm red!) and there are multiple ways it can go wrong.
  8. #28
    Wilco's Avatar
    Aug 2014
    Tucson
    Good help, thx. Tested with kit (Taylor) after gallon of bleach last night and borax the day before. Now at 7.4-7.6 and cl is 5 ppm on Taylor, although correlates at 1-2 ppm on strip. Think I'm ok for a bit, but will get oto kit for use as well.
  9. #29
    If chlorine levels hold overnight, but disappear during the day . . . your CYA is low. If your CYA testing is not indicating this, please watch the CYA test videos linked from the testkit page: http://pool9.net/tk/
  10. #30
    Wilco's Avatar
    Aug 2014
    Tucson
    My cya has consistently tested high, like 100. That is consistent with the history of previous owners using trichlor tabs exclusively. I thinkits more a product of the super hard water here not allowing chlorine to stay free. (?)
  1. Need help w/test results
    By The Mermaid in forum Dealing with Algae & Slime
    Last Post: 10-02-2006, 06:26 PM
  2. More Test Results!
    By mkfmedic in forum DPD-FAS based testing
    Last Post: 09-12-2006, 02:15 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  5. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
