If you have a K2005 kit, you can pick up the add on kit (K1515) that will give you the one test (FAS-DPD) that the K2006 kit has that your kit does not. That test gives you the ability to test chlorine levels higher than 5ppm which is the limit on your kit. You can get the K1515 (or 1515C) through this link:>
http://pool9.net/tk/
(Until your registration is completed, you won't be able to see the rest of the forum or follow that link while you are logged in. So, copy it and paste it into a browser window after you first log out.)
