Re: Need advice in regards to thickness of foam flooring
Hi Dennis, Dennis here. For your purpose the cheaper of the two would be fine. I agree with the instructions you found, 2" of sand or 1 1/2" foam. 1" works if you have a smooth hard packed sand base to install it over. In your situation the 1 1/2" will be perfect.
1/2" should not make much difference in liner fit, you should be just fine not having a 2" base. I would much prefer to have the liner a little snug than have too much liner.
I spent a whole summer installing 48" beaded liners into 52" wall pools simply because they fit better. The hot Arizona sun is very nice for getting a little stretch out of a vinyl liner. Make use of some overhead sunshine and the whole job becomes easier.
A beaded liner installed correctly in the bead should not pull out, especially with the help of a little sunshine.
Later, Dennis
