Results 1 to 10 of 21
Thread: Chlorine tabs w/o CYA
    Jul 2014
    Tx
    Default Re: Chlorine tabs w/o CYA
    I did a bit more reading and discovered 100% sodium hypochlorite is a solid, unstable and very hard to find. Guess that's out.
    Wish I could find an alternative to buying gallons and gallons of bleach every week. Seems like there would be a market for CYA-free tabs if they were available.
    IG concrete 30k gal FNS60 DE filter 2hp single speed Haywood pump
    Jul 2013
    Northern Illinois
    Sure would be a market! Do you have access to fresh 12.5% at least? Even though I use very little chlorine, I use the higher concentration so I have to lug less and recycle less.
    We live very close to where Champion/LC 12 is packaged and distributed so ours is usually above 12.5%. You would think they would do refillables, but don't. That would help with the recycling issue for sure!
    I use refillables--5 gallon carboys. I think Buckman makes and fills them, the same company that makes Polyquat 60%. I have a bunch of older gallon jugs that were filled with 12.5% originally, and I keep them to fill from the carboys.
    BigDave's Avatar
    I use the 5-gallon refillables of bleach (Liquid Chlorine, sodium hypochlorite) as well - I'm pretty sure I get them at the same place as CarlD. I kept the last 5 jugs I bought and refill them for ease of handling. If you do find a cheap source for LC, be sure to pick up a spout and wrench when you but the first one.
    The spout is great. My FAVORITE wrench is the ChanneLock filter wrench. Works on the spout, and also on the quick connects and most fittings. I have a pair of them and abuse the heck out of them as they are the all-purpose pool wrenches!
    Jul 2014
    Tx
    I'll have to look around for a bulk bleach supplier. I'm using a gallon (8.25%) every 2 to 3 days in the summer just to maintain 3-5ppm. (CYA is at 50) Shocking the pool with bleach is going to really be a pain.
    Before we re-plastered, I used the fine granual dry shock. That worked OK, but I'm trying to get away from that.
    I discovered re-purposing my oil filter pliers a couple of weeks ago when I couldn't find my strap wrench and needed to tighten the quick disconnect on my filter pump inlet. They really do work great!
    You may want to consider bumping your CYA up some. Sometimes, people who live places that are very hot and sunny find that having a little higher CYA allows them to dose with bleach less often. One of our former mods lives in NW Louisiana and deliberately keeps her CYA around 80ppm. Just something to think about. If you do decide to raise it some, go to 60 for a couple of weeks and see how that works on your pool and then go a little higher if you want. Gradual increases rather than big changes. Easy to add more CYA, hard to lower it.
    By the way, if you are diligent about keeping your chlorine between the minimum and maximum levels based on your CYA, you should seldom need to shock. Pool stores and pool chemical companies tell you to shock weekly but it isn't necessary. They just want to sell more chemicals.
