Re: Chlorine tabs w/o CYA
Watermom
If you use the trichlor pucks, keep an eye on your pH. They are extremely acidic and will push your pH down.
No problem with the pucks. I have to add a gallon of acid every 2-3 days anyway. My fill water is very hard.
IG concrete 30k gal FNS60 DE filter 2hp single speed Haywood pump
