Re: Vinyl pool leak
I've successfully patched leaks at seams with Boxer 100, including one on the bottom at the corner of the floor and wall. I always recommend double-patching, with the first patch at least an inch around the hole on every side and the second patch at least an inch beyond the first patch on every side. I like to use a rubber tile roller but other people have had success with other devices.
