Test results for today are pH7.3, FC 2, cc 0, TA 90 , CYA<30,
Looking for suggestions on what to add and how much. Thanks
I will be putting a security cover on for winter.
17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward Pro S244T sand filter , Hayward Super pump 1 HP 12 - 24 hrs , using 8.25% bleach, K-2006C kit. PF=7
What is the chemical composition of your "skimmer tabs" ?
What other chemicals do you have on hand?
Bio-gard 3" basic chlorine tabs (99% trichloro-s-triazinetrione) 90% available chlorine, Bleach, Borax, Baking soda and muriatic acid is what I have on hand.
Sorry, one more question. What is your CH and what is your goal? Your fill tested at 150 so you may need some cal-hypo to add calcium as well as chlorine.
Is the CH likely to change? I will check it again this evening. As far as my goal, I want to balance pool chemistry so it can be closed until the spring time. I have hired the local pool store to do the actual closing. I believe they shock the pool and add algaecide, clear and plug the skimmer, returns etc. and put on the security cover. This is my first closing of this pool as we purchased this home in December of 2013. After it is closed, I wasn't planning on touching it again until it is re-opened in the Spring unless I need to.
I would like to know what I need to add, to bring the pool into balance before the closing. Thanks again!
I'm not really up on this thread but under no circumstances let the pool store add ANY algaecide other than Polyquat 60%!
If it says "poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride] 60%" and no other active ingredients, that's the stuff, regardless of the brand or what they label it (Black algaecide, Mustard algaecide, Algae Prevent 60, etc).
ANYTHING ELSE IS LIKELY TO MESS UP YOUR POOL!
Unless they measure the stabilizer (CYA--Cyanuric Acid) level, shocking the pool is probably not going to be effective, because the CORRECT shock level is determined by the stabilizer level:
See our Best Guess table:
http://www.poolsolutions.com/gd/best...ine-chart.html
Here's how I close:
1) Get all test levels to ideal levels
2) Vacuum, brush and backwash to keep it as clean as possible.
3) Turn off all heaters, remove solar cover. Let water chill down to 60deg F
4) Add bleach to raise chlorine level to proper shock level
5) Add 1 quart of Polyquat 60%
6) Wait 48 hours (run pump 24/7) Chlorine level will drop precipitously. This is normal.
7) Add bleach again to shock level.
8) Turn off pump and physically close the pool. (blow out and plug lines, add non-toxic antifreeze to lines as needed, drain filter, drain pump, remove and store pump if possible, etc)
New numbers, FC 4.5, cc 0, pH 7.1, TA 90,CH 160, CYA<30.
I have only used tablets so far. I am going to use Borax and Baking Soda. Would like to know how much I need to add. Is Cal-hypo a powder? How much do I need to add to bring to a safe level? How do I add it? Anything else? I will check on poly quat 60. Thanks
