Results 1 to 10 of 19
Thread: AG Pool Closing with High CYA
    Oct 2013
    Rhode Island
    Default AG Pool Closing with High CYA
    Hello. I have read the sticky thread on Closing AG Pools and am somewhat familiar with the "Best Guess Chart" but I still could use a little hand-holding in closing my pool.
    I started out the season using the "Relax" system that the pool store recommended. It consists of adding some magic dust to the skimmer every week and placing some "pucks" in the skimmer every month or so. Although that system actually worked well at keeping the water clean, it is expensive and after reading on this forum, I moved away from that system and began using just bleach and Borax.
    My CYA levels have been high since I started testing using the Taylor kit this year (over 100 ppm… I began using the Taylor at the same time I started using bleach and Borax). So today my levels are:
    FC=1.5; CC=0; pH=7.3; TA=50; CH=30; CYA>100
    I plan to use a winter cover. I am afraid to bring my chlorine up to the shock levels suggested in the Best Guess chart. Also, I have closed the pool for three seasons by just adding one or two 1-lb bags of shock and the water has always been clear when I opened. Since I wasn't really testing back then, I can't say what the chlorine levels really were.
    Should I really increase Chlorine levels to around 25 ppm? Any other suggestions based on my levels?
    Thank you all for your excellent support!
    Sharkline Escalade RTR 24' x 54" Round AGP; OptiFlo 2-speed pump; Pentair PLM-100 Cartridge Filter; Hayward 250FDN Heater; Taylor K-2006; AquaIlluminator Return
    Default Re: AG Pool Closing with High CYA
    Yes. With a CYA that high, the high chlorine levels won't hurt a thing. It is no different than having a pool with no CYA and a chlorine of 1-3ppm. I would also suggest bumping your pH up to around 7.8 or 7.9 to give it some wiggle room over the winter without dropping below 7.0. You'll also probably want to raise your TA up to around 90-100ish which will help keep your pH more stable.
    Oct 2013
    Rhode Island
    Thanks Watermom. How should I raise TA and do you think I need polyquat?
    Use some baking soda to raise TA. You can use some polyquat if you want. Some do. (I don't in my pool but CarlD does.) It certainly won't hurt anything if you decide to.
    Just remember that Polyquat lowers FC especially if you add a large amount, like a quart.
    Oct 2013
    Rhode Island
    Thanks Carl. So since I do not have an algae problem and since I plan to use a winter cover, should I bring chlorine to maintenance, just above maintenance, or shock levels? I assume from both your and Watermom's sticky posts on pool closing that it needs to be closer to maintenance level when the cover goes on so as not to damage the cover?
    Last edited by bottomcat; 10-13-2014 at 06:00 PM. Reason: To be clear which posts I was referring to
    Jul 2013
    Northern Illinois
    Whoops. Think your questions got missed. Did you close yet?
    Jul 2013
    Northern Illinois
    I think Watermom actually answered that question. It might have gotten missed with the TA recommendation. You asked:
    Quote Originally Posted by bottomcat View Post
    Her reply was:
    (How you didn't have algae with a FC that low, I don't know! You have some luck!)
    Did you have any other questions?
    Oct 2013
    Rhode Island
    I guess I'm all set. Since I wasn't clear in my OP that I was not trying to clear up algae, and since Watermom's sticky is addressing algae, I wanted to make sure I had it right. I was looking for clarification between "it won't hurt" and "it is recommended." I'll just bring it up to around 25ppm (496 oz of 8.25% bleach!) and be done with it. Thanks all.
    Jul 2013
    Northern Illinois
    Perfect! Yea, sometimes things get combobbled on threads. Good luck!
    A piece of advice, open early. When you think the water temperature may be close to 60 degrees, open. Take a full set of readings and post them. We will especially want to see your new CYA reading.
    You are not a subscriber, so unless you update that, you may have to wait for an answer on recommendations. If so, raise your FC right away and use your best judgement on the rest. Better yet, become a subscriber! You can go to the settings tab, then my account, then subscriptions. A minimum of 14 bucks gets you priority attention.
