Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: WHite water mold- new pool owner
    Oct 2014
    east central Florida
    Default WHite water mold- new pool owner
    My I-pool installed in mid July, heater on Oct 11th. I heated it to 84 and used 4 times before noticing quite large tissue in the middle of the very CLEAR water. floating. I used a minnow net with a skimmer sock and scooped and scooped. I found White ( spider mite looking ) creatures floating on my water-they have antennas and legs 3-4 on each side- coming in a variety of sizes- LUCKY ME ! They were their before my Oct 1 water change also-IDK if they have anything to do with my problem. Is this DANGEROUS ?
    I have turned the SWCG and HEAT OFF and have been growing WWM inside a clear class jar on my window sill.
    Then I found YOU "PF"- for 5 days been reading through the forum with my puffy eyes from crying/sobbing SMH. in disbelief. My #'s are: @ a Temp of 70 F
    TC- 3.0
    FC-3.0
    CC-0
    PH-7.8
    AD-2
    TA-145
    CYN-90
    TDS-4,400
    salt-not tested
    Ran through at the "pool store" computer yest. They said to ADD 5.8 Oz of M.ACID- so I bought a gallon, also borax, and baking soda. Have "NOT" done anything yet. :/
    I'm going to vacuum and brush now and will wait patiently for a reply.
    As far as re-testing I only have 6 way aqua chem strips, salt and copper strips too.
    But, I will run a sample back to the pool store tomorrow. taylor kit 2006 is in my amazon cart-havent bought it yet in case you advise me to BUY something additional. THANK YOU very very much. SWEEPMEUP
    AG-Vinyl 1500 Gal 52 inch deep, 8 ft X 6 ft, intx "A" pump 637R, intex SWCG CS8110
    RayVac elec heater-ELS 552-2, skimmer. tayl 2006 in amaz cart -6 way strips atm
    Default Re: WHite water mold- new pool owner
    If "CYN" is stabilizer then your problem is obvious: You need to shock your pool up to a FC level of about 20ppm and hold it there till everything in your pool is dead. What you describe sounds more like a hot tub than a pool: 1500 gallons, 6'x8'. I would start by adding a quart of bleach--8.25%--to your pool, and having the water tested.
    Meanwhile you need to get a better test kit. If there's a WalMart nearby, look for the HTH 6-Way drop test kit, and pick up a gallon of steam distilled water. You can dilute the pool water with the distilled water to double, triple or quadruple the test kit's chlorine reading. 3 parts of distilled to 1 of pool water will mean that "5" on the tester really means "20"...which is where you need to be.
    As for the borax and baking soda--not appropriate. Baking soda with a TA of 145 is about the worst thing you can add. Borax raises pH, but borates in it inhibit algae. Muriatic acid will lower pH but at 7.8 it's tricky to lower it in such a very small pool. So that was pretty bad advice.
    Oct 2014
    CarlD, Yes, CYN is stabilizer-And my "I-pool" is almost like a hot tub- no jets accept for the normal return from pump- My doctors wrote a prescription for 85 degree water for Hydrotherapy 20--30minutes 2-3 times a day. I'm disabled with complex regional pain syndrome. A nerve issue- Do water aerobics and stretching, stationary swimming from a rubber band with a belt around my waist. And use some therapy equipment. Have kept off the 25 pounds I lost in April. so thats good and Noticed my balance has improved greatly. Not my pool. But me. *chuckle
    Anyhow, I did my maint vacuum/brush/skim. had some dark debris on the bottom/ the water had quite a bit of stuff throughout it. couldn't change filter today- have to buy waders tomorrow with the test kit and distilled water. Only my filter is running 24/7 at the moment. But, gosh this water is no clear I can read off the bottom- Will do the bleach- I'm grateful for your reply. SweepMeUp
    What you need to do is get the chlorine level up to 20 and keep it up until the water clears, and the chlorine doesn't drop more than 2ppm overnight. We recommend testing it 2x to 3x/day, vacuuming every day as well.
    Oct 2014
    Carl, I will be vacuuming everyday- Watermom, thanks, I'll do that now.
    Oct 2014
    2006 kit ordered- they had 2 left
    Walmart is out of their kit Carl suggested-in the meantime- I found my old 5way aquachem kit- exp 2011. so I know the chemicals arent good-But I could buy the OTO and PHENOL-RED reagents and test with that kit ? couldnt I ? using CarlD's distilled water method (for getting to 20ppm shock level) and it would keep me OUT OF THE POOL STORE for testing. While I wait on the 2006 kit.
    My old kit was in my house in the plastic box-so my colors look great !
    Yes. Or you could get a simple, new OTO/Phenol kit. If you can, try to find one that goes to 5ppm not 3. Leslies stores sometimes sell the Taylor version of the OTO/Phenol kit, the K-1000 and that goes to 5. If the phenol red reagent is the R0014, that's even better as it neutralizes chlorine and allows accurate readings when the chlorine is higher (Higher FC levels cause pH levels to read higher than they really are).
    If your chlorine level is above 5ppm (or above 10ppm with a Taylor kit), the pH will read falsely high. So, if you need to test pH while the chlorine is high, dilute your sample -- half pool water and half distilled water. Then test and interpret the results as usual.
    Oct 2014
    Thumbs up Re: WHite water mold- new pool owner
    OOPS!!! my husband helped me unload my super-wally-world purchases @ $156 bucks and~~~~I asked him to pour 1/2 of a 2 qt bottle of bleach in the pool. When I walked in the garage I saw the bottle in the recycle bin-
    He had poured ALL 2 QUARTS in my pool WHAT to do NOW ??
    As far as the R0014 at walmart Carl, they only had AQUACHEM replacements and 3 way kits. And only 1/2 of an aisle devoted to pools- in FLoRIDA. hmmm, so now my PH is 7.8 and I did the distilled formula you told me to do ( this kit went to 5 ) Chlorine is a little darker yellow at the 5 line. - I know I'm over 20 ppm.....My pool is covered-SUN doesn't shine on it. It is crystal clear though.
    I'll do another reading in the morning. please advise o.O - And I screwed up BIG TIME !
    Just read your post watermom- I'm on it- thanks..PH is still 7.8 with the 1/2 & 1/2 test
  1. White water mold.Help needed please.
    By raven2963 in forum Dealing with Algae & Slime
    Last Post: 07-21-2014, 11:04 AM
  2. Closing with "pink slime and white water mold"
    By CarolineM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-02-2014, 01:09 PM
  3. White Water Mold/ Pink Slime problem--- First steps....
    By weeznur32 in forum Dealing with Algae & Slime
    Last Post: 07-01-2013, 08:43 PM
  4. White water mold and pool floats
    By formisoul in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-12-2011, 09:06 AM
  5. Pink Algae and White Water Mold in Pool
    By pclstuff in forum Dealing with Algae & Slime
    Last Post: 06-07-2011, 05:26 PM
