Re: WHite water mold- new pool owner
If you cannot get a chlorine reading then you almost certainly are seeing it consumed faster than you are adding it. Not sure what to suggest on the filters. Usually Intex filters can be washed and reused several times, but if you cannot get them out because of the water temp...you'll need someone to do it for you under your direction. But you don't need to change them until they clog up and the flow slows down.
