Re: Struggling to Keep at Shock Level
Thanks everyone.
This AM my CL is up to 12 and my pH is 7.2 after adding more bleach and borax last PM. Didn't test other things. Running out of reagents. Waiting on Ben's reorder to arrive.
Help me understand this please....I know that sun "uses" up the chlorine but others have said test 2-3 times a day to check that you're staying in "shock" level. If you aren't, the solution would be to add CL but doesn't that fly in the face of the conventional wisdom of adding it at night? If the CL levels fall in one of the daytime tests should you wait til nightfall (or sundown) to add what you need or do it right then?
CBean
