Re: Advice Needed
Why does well water disqualify the phosphate control system?
I am entertaining a salt system as we will be away from the house a lot this summer. Looking for something that is easier to maintain as we are away. I have been doing the chlorine method for quite some time and its is easy when we are here.
We are 36,000 gallons concrete pool.
Adding a robot to help clean, the Polaris 380 died along with the booster pump. Going with a 2018 Dolphin Premier Robotic In-Ground Pool Cleaner.
Mike
~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
