JJParrish
Okay folks, here goes again:
1. Our Walmart did not have the cal-hypo, so we used bleach again last night to shock.
You can ALWAYS use bleach for chlorine. It has no side effects unlike all the other chlorination methods.
2. Added appx 2.5 lbs of CYA yesterday around noon. The instructions on the bottle were vague, so we shot for low. (Since the pool store said we needed 5 lbs of theirs, we figured half would be closer.)
That's my method. Now wait a week to test it.
3. When testing the cl this morn, how do we figure how much to add to get back to 15ppm when the kit only goes to 5ppm? We definitely got more than 5 ppm cl this am!
For the CL test, you can dilute with steam distilled water (at all the discount drug chains). If you dilute pool water 1:1 with distilled, you double the range now to 10ppm. 1:2 and you triple it. Search for the CarlD Shot Glass Method!
4. Is Ben's kit ready to ship? I am assuming it will register to 15ppm?
Ben has to answer shipping questions. It will register at least to 50ppm of FC (Free Chlorine), and 50ppm of CC (Combined Chloramines). Your kit measures TC (Total Chlorine) and TC = FC + CC. I THINK it actually goes to 100ppm, but I know it goes to 50 at least.
5. If we cannot find the cal-hypo, can we continue w/bleach and use some hardness increaser from Walmart? Saw a bottle yesterday, but did not buy.
Yup. Just as good if not better.
6. We have lots of staining on the pool floor, esp at the deep end. The pool store said they had something to remove it, after the water clears. But, the stains may alter the perception of the color? It is DEFINITELY getting bluer and clearer. What is the 'color' supposed to look like? Clear or blue?
Sorry, I'm not the expert on stains. All I know is you can try rubbing ascorbic acid on them.
Thanks again for all your help. Joyce
