Thread: Fiberglass Pool Question
    Apr 2018
    Texas
    Default Fiberglass Pool Question
    Greetings from South Texas!
    Had a fiberglass pool installed less than a year ago and I am very happy with the results. Water chemistry is on point as well. The issue that I am having is that after the concrete and grout fully cured, I noticed some white streaks that appear to have leached from the grout onto the side of the pool in various locations.
    Any idea as to how I can safely remove the unsightly stains?
    Thank you in advance for any advice.
    Brian
    Default Re: Fiberglass Pool Question
    Upgraded your membership.
    You are welcome to read the stain-removal guides here. Obviously, I have some ideas about how SOMEONE can "safely remove the unsightly stains". Unfortunately, about a decade of experience suggests that while I can remove stains using those methods, you can not, if you are like about 99% of the other users at PoolForum.
    Worse, fiberglass stains are something of a special case.
    If you want useful help, you'll need to do all of the following:
    • Get a K2006 testkit (or the TFP copy of my old PS235)
    • Test BOTH your pool water AND your fill water.
    • Take good photos of the stains and post them to Google Photos or some other service you can link to.
    • Post ALL the info -- pool photos AND test results -- here and to TroubleFreePools
    Look for responses that start, "I had stains like that, and I did X". (That's why good photos are so important!) You can probably ignore all the other responses and especially those that begin "If you do Y, it might work . . ."
    BUT, the reason most stain removal fails is that removing them is one thing; managing the problems that CAUSED them is something else. Lots of people succeed in removing them briefly.
    Good luck!
  1. fiberglass pool horror
    By CindiKueber in forum --cleanup--
    Last Post: 08-26-2015, 11:53 AM
  2. Fiberglass pool
    By Aboabdo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-01-2011, 05:57 PM
  3. Getting a new fiberglass pool
    By [email protected] in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2006, 10:45 AM
  4. Fiberglass Pool
    By DONNIE in forum Dealing with Alkalinity and Calcium
    Last Post: 07-12-2006, 01:02 AM
  5. Fiberglass pool question - can they pop out?
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2006, 01:32 PM
