Thread: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    Default Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________
    Pool Chemicals to Prefer, & Ones to Avoid
    Blended chemicals are a nightmare for pool owners: they cost more per unit of 'real' chemicals AND they often add unneeded phosphates or pH buffers causing their own real problems.
    AVOID:
    • Any type of chlorine with "BLUE" in the name.
    • Any type of 'shock' or chlorine described as 4-in-1 or 5-in-1.
    • Arm & Hammer brand pool chemicals
    • Biolab brand pool chemicals
    • Clorox brand pool chemicals.
    • Clorox bleach (often contains additives!)
    • Pool Time chemicals (a Biolab brand!)
    • Pool chemicals sold by Walmart or Costco -- ALL that I've seen are blended.
    PREFER:
    (chemicals for small pools in BLUE)____________________________________
    IMPORTANT: Just because a chemical is preferred, you should NOT assume that YOU need that particular chemical. IF you need it, you'll be better off buying a preferred brand than other wise. But, if you don't need it . . . you don't need it, whatever the source.
    Also, you can sometimes get decent chemicals from non-preferred sources. BUT you have to be very careful to read the label!
    Default Re: Pool Chemical Brands to Avoid and to Prefer, 2018
    I did some checking today.
    The problem with the major pool chem companies making a mess of their product offerings is WORSE than it was a couple of years ago.
    There are some decent products hidden among the heavily marketed garbage, but the only way to find them is to
    1. Know how to decipher chemical labels.
    2. Know actual chemical names and terms (like "calcium hypochlorite" and "% available chlorine")
    3. Adopt a skeptical and untrusting attitude toward pool chemical companies, even 'trusted' brands like Clorox!
    Good luck.
  1. What chemicals do we Need for New Pool?
    By ssowell in forum Intex-type Pool Setup & Operations
    Last Post: 06-12-2012, 11:12 AM
  2. Chemicals are off in new pool......
    By drdjsmm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2011, 12:31 PM
  3. Please help with pool chemicals
    By mavswimmer in forum Commercial Pool Users, Managers & Workers
    Last Post: 03-22-2011, 07:16 AM
  4. How/What chemicals to use in pool...
    By drako4 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-25-2010, 05:39 PM
