Results 1 to 10 of 47
Thread: Too much DE in pool
    Jul 2011
    Los Angeles, CA
    Default Re: Too much DE in pool
    If I could find what's wrong with it, it would have been fixed months ago. Are you saying that it will then filter the DE? That that's how I get it out of the pool?
    20,000 gallon plaster (concrete) pool
    DE filter
    Nature 2 (unchanged)
    Jul 2011
    Los Angeles, CA
    I know that the filter has a leak - I've been looking for the source of it for about 3 years. But it's not any worse than it was, and this incident happened some time in March.
    DE filter
    I'm not talking about a water leak. DE will not pass through a functioning DE filter.
    In fact, it won't even pass a functioning sand or cartridge filter ( though it can DAMAGE cartridges!). I've actually used that fact for years to test sand filters.
    Jul 2011
    Los Angeles, CA
    Ah, OK, thanks.
    Well, I can take it apart again, the 3rd time, and see if I spy anything. But I'm pretty sure it would have turned up before.
    DE filter
    It's actually pretty straight forward:
    + You put DE in the skimmer.
    + DE shoots out of the returns.
    + Ergo, EITHER the piping is malfunctioning, and bypassing the filter
    + OR the piping is working AND the FILTER is malfunctioning.
    DE does not pass THROUGH properly functioning DE filters.
    Period.
    But unless you REALLY know the filter . . . and how ALL the icky bits actually WORK . . . finding the bypass point can be a challenge.
    Jul 2011
    Los Angeles, CA
    Yeah, that's what I can't figure out. How could the piping be malfunctioning? It was laid underground almost 60 years ago; I've lived here for 25 years. How could it possibly be bypassing the filter (which is what it seems to be doing)?
    DE filter
    My wife used to say we needed a son named "Frank" so I would not be (frank).
    But I'm gonna be, anyhow: the odds are VERY high that you are simply overlooking the problem inside the filter.
    If you can't find it yourself, get another filter. In theory, you could hire someone, but most of the pool guys I've seen couldn't find their way around a DE filter with 2 flashlights, a manual, and a factory rep helping!
