Thread: New pool owner with 24' x 48" round AG pools
    May 2018
    Missouri
    Question New pool owner with 24' x 48" round AG pools
    We bought a 24’ 48” marquis. I plan on using the BBB method. Any tips or tricks to master this? Any must haves for the pool? I bought a tester kit and skimmer socks
    Default Re: New pool owner with 24' x 48" round AG pools
    I assume the pool is filled?
    • 24' x 48 => 11,800 gallons (unless the bottom is dished). PF=10.1
    • 1 gallon of PLAIN (no flavor, no gel, no scent) 6% bleach will add (0.5 x 10.1) ppm of chlorine or ~5 ppm)
    • 1 gallon of 10% pool bleach will add (0.85 x 10.1) ppm of chlorine or ~ 9 ppm.
    • pH UP adjustment dose = 1 cup measure of borax
    • pH DOWN adjustment dose = 1/2 cup measure of muriatic acid
    So . . .
    If you can find this HTH 6-way at Walmart, get one. Otherwise order one from Amazon. (Yes, you'll want both).
    While you are at Walmart, buy:
    Test your pool in the EVENING. Make SURE the pump is OPERATING.
    1. If chlorine level is below 2 ppm, add 1 gallon of bleach or 1/2 gallon of pool bleach.
    2. If pH is below 7.2, scatter 1 cup measure of borax in the pool.
    3. If the pH is above 7.8, you will need some acid from Lowes or Home Depot. Read the "Using muriatic acid" article linked in my blue signature.
    4. Report results and actions in THIS thread.
    5. ALSO, list any chemicals that have ALREADY been added.
    Good luck!
    [ Membership upgraded; thread move to pool startup section; you made need to log out and back in to see everything; posts are STILL moderated before appearing.]
    PS. If you got a salt system with the pool, take it back if at all possible. No matter what you're told, salt systems will DESTROY AG pools!
  1. New to pools - is "root kill" (copper sulphate) good to use?
    By duffmama in forum Dealing with Algae & Slime
    Last Post: 05-28-2013, 10:53 AM
  2. Just filled new 15' round 52" H permanent pool
    By mroll in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-25-2012, 10:35 PM
  3. Searching for more about "Operating Swiming Pools at High PH"...
    By Sponge1971 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-28-2011, 11:51 AM
  4. Bought a 27" ag round tonight
    By pkzmf in forum Above-Ground Pool Construction & Repair
    Last Post: 05-06-2006, 01:04 PM
