Results 1 to 1 of 1
Thread: What Does It Cost to Operate an Intex, Bestway, or Summer Waves Pool?
    Default What Does It Cost to Operate an Intex, Bestway, or Summer Waves Pool?
    ________________________________
    What Does It Cost to Operate an Intex-type Pool?
    Incomplete!
    Unfortunately, more than you'd think.
    Why? There are a number of reasons:
    • Cost of testkits is the same, regardless of pool size.
      (And even with Intex-type pools, becoming a victim of pool stores and pool chemical companies is EXPENSIVE!)
    • Pool chemicals cost more in small sizes.
      (Dichlor costs $2.20/lb in a 50# bucket at Sams, but as much as $12.00/lb in sizes for kiddie pools!)
    • Intex pools are often used MORE than inground pools . . . and people goo 'eats' chlorine on a per-person basis.
    • Inground pools aren't usually drained annually; Intex pools usually are.
    • And . . . so on.
    So . . . the costs:
    Testkits + refills for a summer
    1st yr: $100 (HTH 6-way + K2006 + CYA refill)
    2nd yr: $40 (OTO refill; Chlorine + pH + CYA refill for K2006)
    Electricity
    Using $0.18 per KWH.
    KWH rates can vary from $0.08 to $0.40 or higher. California and New York are expensive. Hawaii is VERY expensive. Intex type pumps seem to use between 300 and 700 watts when running. I have assumed you'll buy a $25 timer and run 12 hours per day.
    Cost: 0.4kw x 12 hours x 30 days x 0.18 $/kwh = $26/month
    Water
    Using $0.012 per gallon.
    Water rates vary a LOT from place to place. Often water costs MORE if you use more, so pools are charged more per gallon than basic usage. Generally sewer charges are based on water use, so you pay sewerage even for pool water!
    Calculation is based on initial fill + 20% splash out monthly
    Cost:
    10,000 gallons x 0.012 = $120 to fill
    10,000 x 20% x 0.012 = $24/month
    Chemicals
    Chemical costs assume you can purchase from Walmart, Sams Club and Lowes. Costs can be 2x - 4x higher if you do not have access, or if you use 'branded' chemicals like Clorox, Arm & Hammer, HTH, etc.
    Bleach
    Dichlor
    Muriatic acid
    Borax
    Filter cartridge
    All Intex-type pools have marginal filters. You NEED a spare cartridge, if you don't have a sand filter. You'll consume 1 - 2 cartridges per season.
  1. What does it cost to operate a 4,800 gallon Coleman for the summer?
    By PoolLover in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-31-2018, 04:58 PM
  2. Convert a Summer Escapes / Pro Series pool to use an Intex sand filter & pump
    By eblade21 in forum Intex-type Pool Setup & Operations
    Last Post: 08-26-2014, 02:57 PM
  3. Cost of Maintaining 4,400 Gallon Intex Pool
    By ransomedbyfire in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-25-2014, 05:43 PM
  4. Intex filter w/Summer Escapes 18'x48" pool?
    By JoeMik in forum Intex-type Pool Setup & Operations
    Last Post: 04-08-2014, 12:06 AM
  5. Contact info, BBB reports & Reviews of Intex, Summer Escapes & Bestway pools
    By PoolDoc in forum Intex-type Pool Setup & Operations
    Last Post: 08-17-2013, 08:19 AM
