First post, I'm an Intex above ground pool owner getting bids for an in ground pool and came here for advice and research purposes.
Probably be lurking for awhile until some of my bids come in then the questions will start.
Thanks for having me.
[ Upgraded membership; moved thread to "IG Pool" section <= you may need to log out and back in, before you can see everything.
I'm going to be reworking and rewriting all the guides in the IG pool construction section, over the next couple of days, so you may want to use the link (IG Pool Construction) to check it out.
PoolDoc / Ben
