Thread: SWCG (Salt Water Chlorine Generators) - Pro & Con
    Default Re: SWCG (Salt Water Chlorine Generators) - Pro & Con
    Jim,
    What size AquaRite do you have?
    How long does your pool stay uncovered each season?
    What CYA level do you maintain?
    How do you 'shock'? (SWCG or manual)
    . . . it may be, I need to add a "How to have an SWCG and NOT regret it!" section.
    Virginia
    Jim,
    1. T 15 cell (rated for 40k gal pool). “Oversizing” is important, IMO.
    2. Pool stays uncovered all season; 5 - 5.5 months here.
    3. I keep CYA 70-80
    4. The only time I “shock” is at opening and closing, using plain bleach. If I ever need to increase FC during the season, I do so with bleach. The SWCG is only used to maintain the FC level.
    Btw, I thank you for my good experience. Before finding this site many years ago, I was relying on my pool store for testing, advice, and chems. After a couple seasons or so it was obvious what I was doing wasn’t working well (and was expensive!), so I started searching the internet and found this site whereI learned proper care of my pool and proper SWCG use.
    (Edit: Sig updated with cell size)
  1. Salt generators
    By Maurice in forum --cleanup--
    Last Post: 04-25-2014, 11:47 PM
  2. Problems with SWCG (salt water chlorine generator) on inground pool
    By jdubose in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-22-2014, 10:16 AM
  3. Salt generators - are they worth it?
    By clark in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-22-2012, 02:31 PM
  4. Salt water generators voiding the AGP warranty
    By laurieeas in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-06-2011, 07:31 PM
  5. Salt Generators
    By Calcutta in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-11-2006, 10:41 PM
