Thread: Intex SWCG pool problems
    Jun 2018
    texas
    Default Intex SWCG pool problems
    24' round - 13,200 gal => 9
    Hi, I'm a first time user of the Intex SWG system. I'm trying to adjust the salt level. The size of the pool is 24'x54" round, the text strip that I used was AquaCheck7 the results were
    Free chlorine 3
    T chlorine 3
    Stabilizer 50
    Alkalinity 120
    Hardness 250
    Could you please help me with this problem, I've drain the pool twice but I guess not enough.
    Please help, thank you.
    Default Re: High Salt level Intex SWG
    Not sure what the problem is; your numbers are fine . . . though I don't trust the test strips, especially for the highly important CYA/stabilizer result.
    Why did you drain your pool?
    BTW, do you realize that using salt water in tube frame Intex pools OFTEN results in premature failure of the framework? And it is NOT covered by any warranty.
