Thread: Intex Easy-Set leaning
    Default Re: Leaning pool.
    [ Upgraded membership; moved thread to "Intex-type pool" section <= you may need to log out and back in, before you can see everything. ]
    Jun 2018
    Iowa
    Default Re: Intex Easy-Set leaning
    You are correct on the size and yes I was aware of the weight when I built the platform. The platform was built because over the 16’ length of the platform there was an 8” drop right to left.
    My wife got the pool for free from a friend and wanted it up quickly so while it will have to wait until fall to get prettied up I can assure you it was “engineered” and built properly. The outside is level and I even put on the goggles and put the leave on the bottom of the pool. Checks out there as well.
    My main question is how do you get it to fill evenly? I had it filled once and it stood up fine. I drained it to reposition so the filter ports were in a better position and it rolled over during the refill. I must have gotten lucky the first time.
    Btw, the overal weight might be 6 tons but the pressure per sq.ft. is roughly 156 lbs. so when building a deck or platform it need s to be able to hold whatever the weight is per sq.ft.
    Quote Originally Posted by brant View Post
    I assume you are thinking of building codes. Unfortunately, they do NOT assume that the maximum per sft live load will ever be present across the entire area, or even in a single concentrated area. You can see this at play in Table 1607.1 of Chapter 16 of the IBC As you can see, point loads considered never approach 12,000 pounds!
    As far getting to fill evenly, my understanding is that the only 'trick' is to put the pool on a genuinely level surface. I believe it is the case that the frame pools are more tolerant of out of level surfaces than the Easy-Set models.
  1. Intex Easy Set 15' x 36"
    By hollyp53 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-25-2014, 09:52 AM
  2. 12x24 Intex Ultra Rectangular Pool setup - what about walls leaning in?
    By SusanG in forum Intex-type Pool Setup & Operations
    Last Post: 05-27-2014, 03:13 PM
  3. Buy JUST the Intex Easy-Set Pool?
    By donovan.lambright in forum Intex-type Pool Setup & Operations
    Last Post: 03-10-2014, 12:33 AM
  4. Intex Easy Set Cover
    By Beastcadet in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-21-2013, 03:34 PM
  5. Easy Set Intex Pool
    By Naunnie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2011, 06:04 PM
