Thread: Cloudy water & strange test results - pH 9.0
    Jun 2018
    Ontario
    Default Cloudy water & strange test results - pH 9.0
    I have always had a cartridge filter for my Hydro Force above ground pool. This year a friend gave us a Hayward Ultra-ProLx pump and a Hayward Pro Series sand filter. I just used a test strip in my water..
    The readings are as follows: FAC=2, TCL=5, ALK=120, PH=9.0, TH=100, and CYA=30-50...
    Water is cloudy.. Please Help... What do I do? I would like to use the BBB method if possible.
    Default Re: first time sand filter and pump user
    If "FAC" = free available chlorine, and "TCL" = total chlorine . . . you've got goop in your water that has NOTHING to do with your filter.
    There are many possible kinds of 'goop':
    + ammonia based algae treatments (Green to Clean, Yellow Out, etc)
    + bromine based algae treatments (anything made by United Chemical)
    + partially 'eaten' stabilizer (if you didn't drain and refill your pool)
    + X-in-1 pool 'chlorine' that is mixed with only God knows what. (Clorox, Arm & Hammer pool chems, and many others)
    But . . . I don't trust your testing!
    Unless you used a freshly calibrated pH meter, there is no way you could get a result of "9.0". Your pool could BE at 9.0 -- a huge dose of pH Up would do that -- but you just couldn't test it: no pool test methods measure that high.
    So . . . get a HTH 6-Way Test Kit from Amazon or Walmart, retest, and report what you find.
    [ Upgraded membership; moved thread to "Testing & Adjusting Pool Water" section <= you may need to log out and back in, before you can see everything. ]
  1. Strange test results -- very high combined chlorine (CC)
    By Themadczar in forum Dealing with Alkalinity and Calcium
    Last Post: 08-05-2013, 11:27 PM
  2. Water cloudy, have test results
    By sbillingsley in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-01-2012, 03:07 PM
  3. Strange test results, help!!
    By lisak in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-20-2010, 04:59 PM
  4. Help with test results and cloudy water
    By superjet in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2006, 01:05 AM
  5. Test Results - Cloudy Water
    By quenterry0 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-06-2006, 06:28 PM
