Thread: Rebar Stains
    Default Re: Rebar Stains
    Lots of old pools have stains.
    Whether they are a "problem" depends on you. Stains don't interfere with swimmers or pool water.
    But will it get worse? Probably. Can you fix it by re-plastering? Maybe. Ask your plastering contractor. Local skills vary a lot, and it would be useless for me to speculate on methods that aren't available to you locally.
    Could you fix it yourself? Dunno. I could fix it, myself, even though I've never been a pool contractor or a plastering contractor. But I do have 20+ years of varied construction and repair experience.
    What I would do (probably! I haven't seen it) is
    • Drain the pool
    • Keep the pool surface wet with a sprinkler, connected to a pump in the deep area
    • Chip out the gunite to expose the rebar.
    • Refill with a high-strength patching cement (like this)
    • Finish with plaster (white cement / marble dust)
    • Refill.
    But, that can't be done in super-hot OR super-cold weather without risking damage to your pool
    Jun 2018
    NV
    I had a pool guy out that told me he would do the repair the same way you explained it.
    The stains don't bother me but I wasn't sure if this was something that had to be repaired right away or I could let it go for awhile and see if other stains develop.
    If you aren't experiencing accelerated salt corrosion, my guess is that there's no particular urgency to it. And, you definitely don't want to expose your drained and dry to Las Vegas sun and heat. That would be likely to cause damage to old plaster.
    Good luck!
