Thread: Pentair IntelliChlor IC60 reduced output?
    Default Re: Pentair IntelliChlor IC60 reduced output?
    I purchased your old test kit so I look like a mad scientist when I do my tests. I also have extra R-0013.... Ill measure later tonight and let you know. I don't know for sure if the IC60 is working because I cleaned it but need a new cartridge filter first.... I will also try the tabs but I am not on a well.
    One more note. I had to disconnect my SWCG because it is still not functioning properly. went back to bleach, and did the stair test. It was organic! Next decision is to purchase another IC60 or go with one of your recommendations. Thanks for the help.
    One thing I didn't think of: you want to make fairly sure your power supply is functional, before purchasing a new IC60 unit. Are the lights coming on, on the electrode unit?
