Hm-mh. What you are describing is the floc working the way it many 'floccing agents' SHOULD work.
Did the label or the pool guy not tell you to turn the pump off and let things 'settle', after adding floc?
Anyhow, glad it is clearing up. Is the water clear?
Quote Originally Posted by meme2 View Post
+ My PH is still a little high do I need to bring down or leave? (8.0)
Your pH should be between 7.2 & 7.8.
+ I assume that the ionizer will still work with the chemicals ill be using.
Not necessarily. You need to post your pool info: gallons, pool type, filter type, pump type, ionizer type.
+ So just need chlorine and ?
Chlorine, pH control, stabilizer, for sure. Other stuff depending on info I don't have yet.
+ Leave the pump on low always?
Unless you have a specific reason to put it on high, yes. Again, I need more info about the pool.
