Re: Nobody knows! Help Is it phosphates, water to hard.......
ok I'm back, water test I used OTO drops for chlorine 1.0-1.5, phenol red for PH with was 8. I also have a 6 way test strip kit hardness 500, chlorine low, free chlorine ideal, ph high 7.8, total alkalinity high 160, stabilizer ok 50.
I will text you the pictures of the pool, pump and simple salt system.
You asked about the budget, well don't want to spend and arm and leg but want to do what I need to do. Question, did I mess the pool up by mixing different chemicals? Not me but getting different pool people to test water and suggest stuff. Only asking.
I don't have anything to test for phosphates. we have had to add water the last couple of days due to hot weather and all the vacuuming. Yes we have well water thats softened with water softener. I don't know about the manganese and sulfur, I would say a little bit of iron but I don't have iron built up in anything toilet or sink. I can by pass the softner and run straight well water. I have never had any staining with the ionizer (maybe it didn't work?).
The pool today was the best its been blue and clear. We have vacuumed 4 times on waste.
ok hope I have given you all the information you needed and Im gonna send the pictures now.
I have gotten the Walmart pool chlorine and ph down and also gotten the borax. oh ionizer is unplugged!
