Re: Bucket test accuracy
Well, setting the bucket deeper in the pool water has definitely eliminated any temperature differential. Both are 86 degrees as of 8am this morning.
I'm still losing about 1/4" more water in the pool than in the bucket over 24 hours. But I'm not sure I'm getting a good reading on the levels. The bucket is less stable on the second step and wobbles around a lot. I also had to pull it out for a few hours because our granddaughter came over and wanted to swim. So I'll have to reset everything today and try to get it more stable on the concrete block.
I also need to add some water to the pool... still losing right at 0.44 inches per day after 5 days. My hole in the ground where the pipes are exposed is still dry as a bone. I'll post again after I have a better reading on the bucket levels.
My son was here also. He was a pool tech for 4 years and also owns a pool now. He said that he loses 2.5 to 3 inches per week, which works out to be 0.35 to 0.43 inches per day. From his tech days, he said that evaporation up to 1/2" is not unusual this time of year in Texas. He also said the bucket test is only reliable if you are seeing large differences of at least 3/4" or more.. something about the larger surface area for the pool.
__________________________________________________
35X20 in-ground gunite, free-form, 18k gal, pebbletec plaster, Pentair cartridge filter, Pentair 1.0 HP WhisperFlo pump, Polaris 280, heater, waterfall, Taylor K2006 kit and K1106
