Thread: Suction leak
    Apr 2018
    Alabama
    Default Suction leak
    I think I've got a suction side leak of my main drain line. is there a way to positively check this?
    Default Re: Suction leak
    Suction leaks lead to air bubbles in the water line . . . when the pump is running.
    They may, or may not, result in water leaks when the pump is off. They also are notoriously hard to find. Many service guys opt to 'fix' all 'dodgy' connections in hopes that one of them will be "THE" leak. Only when that fails, will they actually search for a specific leak.
    Good luck.
    PS: There's little anyone can do to help via the Internet. If you really want online help, you'll need to post complete info about your pool, pump, & piping . . AND pictures. Here's how: http://pool9.net/postpix/
    Upgraded membership and moved thread to the pool repair section. You may need to log out and back in to see everything.
  1. In-ground suction leak
    By donwfree in forum Pool Equipment & Operations
    Last Post: 05-01-2014, 04:14 PM
  2. Suction Air Leak Causes Skimmer to Spew
    By chuckerman in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2012, 08:20 PM
  3. Suction Leak Causes Pump to Run Dry
    By mwagner in forum Pool Equipment & Operations
    Last Post: 08-24-2007, 02:53 PM
  4. Suction Side Air and leak
    By lcrooks in forum In-Ground Pool Construction and Repair
    Last Post: 05-13-2007, 12:02 AM
  5. Suction side leak (PIC) am I close???
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-15-2006, 04:49 PM
