Thread: cloudy water day 5
    Default Re: cloudy water day 5
    Post your ACTUAL test results.
    If your water is cloudy . . . either your results aren't actually perfect OR you have bogus test kits (common!) OR your filter is not working properly . . . OR a few other possibilities.
    So, ALSO include testkit make/model info, pump & filter make/model . . . and recent dosing history (did you add a bunch of calcium, clarifier, or 'floc'?)
    Upgraded membership and moved thread to the pool water problem section. You may need to log out and back in to see everything.
