Thread: Pool Alarms
    Aug 2018
    ohio
    Default Pool Alarms
    We are considering a pool alarm (like the one where water disturbance sounds an alarm in case a child falls in).
    However, I've reviewed many of the products in this market and it seems like just about all the manufacturers have plenty of complaints about either false alarms or they just do not work as advertised. Some are based on surface water movement while others are based on water displacement.
    Does anyone have any advice or experience on a good recommended pool alarm? This is for an inground pool
    Thanks.
    Default Re: Swimming Pool Alarms
    I have little experience with pool alarms of the sort you mean -- they are not used commercially -- but lots of experience with other times of alarms, and sensors . . . and there's a fundamental problem with almost all alarm systems:
    • If an alarm systems is sensitive enough so it never misses a valid TRUE alarm (like a kid falling in), then it is also sensitive enough so that it will have many false alarms!
    • Conversely, if an alarm is set to avoid all false alarms, then it is also set to MISS some TRUE alarms!
    The only way I've seen around this is to combine an alarm with a camera, so you can easily check each alarm, and then reset it, if it is not a true alarm. I spent a few minutes with Google and Amazon, and looked at some of the "top 10" lists . . . and didn't see anything I'd recommend.
    What might work well is a conventional alarm system, with a motion detector on the pool deck, a camera on the pool deck, and gate alarms. I personally use the SimpliSafe system (https://simplisafe.com/) and could set one up -- for myself -- if I was trying to do what I described. On the other hand, I know the conventional monitored alarm my uncle has on his property would be a total pain set up that way.
    Bottom line?
    I don't think there is any 'works out of the box' pool alarm solution that is better than mediocre.
    Sorry!
    Upgraded membership and moved thread to the Pool Electronics section. You may need to log out and back in to see everything.
    PS.You can search use Google to search multiple pool sites, using Google's 'advanced search operators" to limit your search to specific sites. This page of mine will create the search links for you. Google knows my site -- and all the others -- much better than those sites internal search functions! And, if you need to post pictures -- of your pool, filter, pump, piping, what-not -- there are instructions on this page
    Aug 2018
    ohio
    Default Re: Pool Alarms
    Thank you For the quick response!
    Mark
