Results 1 to 10 of 12
Thread: Availability of 8.3% Bleach Is Nil
    Mar 2014
    NC
    Default Availability of 8.3% Bleach Is Nil
    Hello everyone. It has been a while!
    I wanted to ask the group if they are having a hard time finding 8.3% bleach these days? It is like it has come off the market? Our local WalMart doesn't have it nor does one single grocery store within miles. We keep looking but can't find it. We did find a source at Home Cheap-O, but you guys all snatch it up and it is rarely in stock. What gives? I mean, it doesn't look like the stores are out necessarily because we don't even see empty spaces. It's like the industry caught on to us and have decided to bend us over. Anyone have a clue?
    Thanks!
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
    Mar 2014
    NC
    Default Re: Availability of 8.3% Bleach Is Nil
    The title might be misleading... Any 8+% is hard to find. I pulled the 8.3 number out of my head. Sorry :-)
    Virginia
    This past spring Kroger was still selling 8+% in our area. It’ll be interesting to see if they still have it this fall when I close.
    As of 2018, it seems the market has reverted -- following Clorox -- to 6% household bleach as a standard.
    But . . . Walmart has begun selling 10% pool bleach very widely, and for the same price as household bleach. You can check Walmart.com to see which stores local to you stock it.
    Jun 2015
    Shallotte, NC
    Locally, the price of 10% Wal-Mart pool bleach is $3.22/gal. and the jugs are quite old (3-6mo.+). So, having calculated the labeled chlorine content and still at Wal-Mart, we are buying the green labeled 6.0% "cleaning" bleach for $1.77/gal. It works out to be cheaper.
    Do we have a calculator here?
    Aug 2016
    Houston, TX
    Here in Houston area, Aldi sells 8.25% for around $2.68.
    @Palmyra: Interesting. Locally, Walmart store brand plain bleach, and the pool bleach are nearly the same price. I'll have to check dates on the bottles I've seen. -- No calculators here, sorry. --
    @Andy49: Thanks for that info. I'll have to check and see if that's true locally. If so, it may be true nationally.
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    In years passed, used 8% cleaning bleach from Walmart, but they stopped carrying that so went to the 10% "chlorinating liquid", but it seems our local store orders at the beginning of the season and when it runs out, its gone, and they won't order anymore.
    Jun 2015
    Shallotte, NC
    Quote Originally Posted by swimdaddy View Post
    This is very similar to our experience. Our local Walmart usually has 10% "chlorinating liquid" left at the end of the season and they carry it over until the following spring. Some of it can get pretty old, before anybody takes it....
    20'x40' rectangular 25.5K gal IG vinyl pool; Hayward S270T sand filter; 1 hp Hayward Pump (SP2607X10; K-2006C
    So long as it is stored INSIDE the store (below 80 deg F), it should be fine.
    I looked at the bottle I have; how did you decode the date?
  1. Pool Enclosure Cleaning - Oxygen Bleach versus Chlorine Bleach
    By bell7272 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-09-2015, 07:38 PM
  2. Storing bleach outside; decomposition of bleach
    By tmess13 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-03-2013, 08:24 PM
  3. Is it possible to add to much bleach?
    By drako4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2011, 05:44 PM
  4. how much bleach???
    By cappy2449 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-27-2006, 12:43 PM
  5. where to add bleach?
    By kjmelak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-26-2006, 11:30 PM
