Thread: New Above-Ground Pool from FamilyPoolFun.com
    Aug 2018
    ND
    Default New Above-Ground Pool from FamilyPoolFun.com
    We are looking at a Grand Bahama EZ 54" - 27' round above-ground pool. Has anyone had any experience with this pool? Thanks for any advice!
    Default Re: New Pool
    This one? http://www.familypoolfun.com/shop/ab...pool/grndbma15
    The pool comes with an American pump/filter (StaRite) which is definitely better than Chinese branded stuff. It may not be made in the US, but at least it has a US warranty.
    Anyhow, the pool doesn't look bad . . . but it looks like a non-branded dealer special for "Familypoolfun.com", which means it will be nearly impossible to get comparison info. I'd recommend instead you search for the seller online -- BBB, etc.
    Good luck!
    Upgraded membership and moved thread to the AG pool construction section. You may need to log out and back in to see everything.
    PS.You can search use Google to search multiple pool sites, using Google's 'advanced search operators" to limit your search to specific sites. This page of mine will create the search links for you. Google knows my site -- and all the others -- much better than those sites internal search functions! And, if you need to post pictures -- of your pool, filter, pump, piping, what-not -- there are instructions on this page
    Please note: the Super Search page does NOT search directly; it only CREATES special Google links, that enable a FOCUSED Google search!
    Aug 2018
    ND
    Red face Re: New Above-Ground Pool from FamilyPoolFun.com
    Yes, that is the one we are looking at. Thanks for the help. I'm going to be doing even more research today. We have been without a pool for about 10 years and really looking forward to having one again.
  1. Using an in ground cleaner in an above ground pool
    By Johnnymac in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-11-2012, 09:03 AM
  2. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  3. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  4. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
