OK.
Actually, things are pretty straight forward.
1. Go to the Walmart or whoever, and get 10 gallons of PLAIN 6% bleach (or 10% pool bleach "chlorinating liquid", if it's still available.) Add 2 gallons in the EVENING. Test your chlorine before you add the bleach, and again in the AM. Doing this will not only help you get rid of your algae, but will give us a data point on your pool volume.
2. Keep adding soda ash (available CHEAPLY at Walmart as "Washing Soda") till your pH is slightly above 7.0
3. Once it is, STOP, and test both alkalinity and calcium levels.
4. ALSO, stop using all the 4n1, 5n1, Xn1 products you have AND any tabs or products that contain trichlor or dichlor. If in doubt, ask me before you use it. EVERYTHING you've mentioned using, except the bleach, is adding to your stabilizer level, AND causing other problems. If you've got a friend with a pool, plan to give them that stuff.
5. AND . . . retest your CYA. But THIS time, fill a measuring cup 1/4 with pool water, and then 3/4 with tap water. Mix. Test. Multiply the results x4.
6. Finally, your FC level should be AT LEAST 5% of your stabilizer level, if you want to control algae. In your case, this means 10 ppm is the MINIMUM acceptable level! And yes, you can swim just fine with FC=15, when CYA = 200+
7. And about gallons. You supplied your address with registration. Look up that address on Google Maps satellite view. Is that your house? (You have a spa, right?) If it is, I can show you how to calculate gallons. But you'll need a tape measure like this: Komelon 6611IM 100ft Fiber Tape Reel
Good luck!
