Results 1 to 10 of 10
Thread: My water needs help
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Default My water needs help
    I'll keep this brief.
    1. Last weekend I vacuumed the brown winter algae to waste and topped off the pool. Water clarity was decent. I could clearly see the bottom liner. Started the filter. See Photo 1.
    2. This weekend (Fri) I lowered pH to 6.8 for a treatment of Robelle Metal Out using muriatic acid.
    3. Sat morning I added 6 cups of Dichlor. By noon my readings were pH-6.8, TA-90, FC-12.5, CYA-80.
    4. Water clarity deteriorated and is now aquamarine/milky, vis = 16 inches. See Photo 2. All brown algae seems to be gone.
    5. Filter running 24/7. Visibility not improving.
    Is someone tells me how to post photos, I have some to show.
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    Default Re: My water needs help
    1. http://pool9.net/postpix
    2. Do the DE test on your filter: http://pool9.net/de-test/
    3. Use borax -- NOT soda ash -- to raise your pH back to 7.2 or more.
    4. Post exact quantity of Metal Out used. (Why did you use it? Brown algae is not associated with metals; "Metal Out" does NOT remove metals from your pool, except as a part of a complex process they do NOT explain!)
    Aug 2012
    Nebraska
    Thank you for the reply.
    36 oz of Metal Out. (32 oz / 10,0000= gal, I have 12,000 gal)
    The metal out is just to stop the oxidizing of the iron before adding chlorine for the fist time of the year.
    Apologies for the big image sizes.
    1 week ago. Nothing added, this was the winter condition. pH was 8.0+
    Now, a week later with 36 oz Metal Out, muriatic acid (pH = 6.8) and dichlor.
    My current test are in yellow results so far. (Ignore the 2013 entries.)
    Aug 2012
    Nebraska
    I haven't seen that DE test thread.
    I'll look into that and report back.
    The fact that the water was clear, but became cloudy after vacuuming, is pretty strong evidence of under-performing filtration.
    This problem is very, very, VERY common on above-ground pools, since AG pool kits almost always match an undersized filter with an oversized pump. This causes a variety of problems, but with sand filters, it usually results in the loss of sand with each backwash.
    Unfortunately, since sand filters sold with AG pools are almost always top mount valve, rather than side mound valve, adding more sand is a PITA.
    Aug 2012
    Nebraska
    I vacuumed all that algae to waste, so it shouldn't have gone through the silica sand. But...
    I'll look into the filter. I think I replaced it (and the sand) 3 yrs ago. Maybe 4.
    I'll report back.
  1. Pool building Photos 1
    By beary in forum In-Ground Pool Construction and Repair
    Last Post: 07-07-2006, 08:20 AM
  2. Photos of my DIY gunite pool
    By y0manda in forum In-Ground Pool Construction and Repair
    Last Post: 06-26-2006, 04:28 PM
  3. 24ft AGP Installation Photos
    By fhcaputo in forum Above-Ground Pool Construction & Repair
    Last Post: 04-16-2006, 10:17 PM
