Thread: Help!! How Do I measure Chlorine Levels
    Smile Help!! How Do I measure Chlorine Levels
    We have a test strip kit... I know I need a drop based, which we'll buy at walmart because we don't have a leslie's or bob's (or whatever these stores you're all talking about near us). The drop based test kit... how many tests should i get. Our test strip now tests alkaline, ph, and bromamine. So what do we need to get to test everything we need to? What is CYA and what is CL
    Default Re: Help!! How Do I measure Chlorine Levels
    CYA is cyanuric acid, also called stabilizer or conditioner.
    CL is chlorine
    You can buy the 5-way drops based kit at Walmart for about $13. Post results when you get your new kit and also tell us what type and size your pool is.
    Philly Burbs
    What are the five things that the kit tests?
    South Central PA
    In case you are referring to the HTH 5 way kit, it measures total chlorine, ph, alkalinity and stabilizer. The fifth is hardness, in case you need that.
    See CarlD's post for a link to a more detailed explanation of those types of tests and what to do about the results. The HTH kit at Wal-Mart is an OTO test kit.
    IG 30,000 gal vinyl
  1. Can't keep chlorine levels up
    By cbednara in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2012, 04:53 PM
  2. chlorine levels
    By fhorta in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 06:26 PM
  3. Need Help with Chlorine Levels
    By stateroaddog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2008, 09:09 PM
  4. What test kit will measure chlorine levels above 5ppm?
    By Tillysaint in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-13-2007, 04:20 PM
  5. Low Chlorine Levels
    By BigButz in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2007, 08:42 AM
