Re: Newbie first test results. Some questions?
I'm not so good at giving advice as I usually need advice, but I have the same size pool Intex metal frame. I read on here to put a stocking held in place with a rubber band inside the skimmer. i tried that but it kept floating up, so I put over the outside of the basket that goes in the skimmer. It works. Picks up fine stuff. Have to clean mine at least once a day tho. I use a ladies knee high stocking and if on the outside of basket you don't need a rubber band.
