Results 1 to 9 of 9
Thread: What is this residue and how do I get rid of it?
    Unhappy What is this residue and how do I get rid of it?
    I thought I might have mustard algae because there were brownish yellow spots on the bottom of the pool-always in the same places. I have treated with Yellow Rid and shocked numerous times and vacuumed to waste. The pool floor and sides remain clean until I turn the filtration system back on. Then the same places return in less than 12 hours. I'm sure its coming from the filtration system but how do i get rid of it? I have poured in sand cleaner at the recommended amount. The water is sparkling clear, but the residue on the bottom continues to return. It poofs and vacuums easily. What could it be????
    Default Re: What is this residue and how do I get rid of it?
    What are your numbers? I think your chlorine level is too low to kill it off.
    My test kit doesn't actually read higher than 5 but I keep it MUCH higher. I shocked using 6-8 bags of 62% calcium hypochlorite over 48 hours in addition to HTH algaecide initial dose, then continual pucks in the skimmer. I have a sand filter. The ph is 7.6. The water in the pool and the pool floor stay perfectly clear until I turn the filtration on. Is the stuff living in the system?
    You need to post a complete set of water testing results for us to really be able to advise you. (FC, CC, TC, PH, alk, calcium hardness and CYA) If your kit doesn't test for all these, give as many as you can, but we especially need to see a CYA reading. To make your test kit test higher cl levels, you can dilute your sample. Take one part pool water, and mix it with one part distilled water, test as usual and then multiply result by 2. If you need to go higher, one part pool water, two parts distilled, then multiply by 3, etc. With each dilution, you lose some accuracy, but it is better than nothing. You can buy a kit that tests higher than 5 at the sister site to this forum. www.poolsolutions.com
    We also need to know the volume of your pool and if it is vinyl, fiberglass, gunite, etc. Welcome to the forum.
    Smile Re: What is this residue and how do I get rid of it?
    Thank you so much! Will purchase a new test kit today. The pool is in-ground vinyl, 16x32, about 20,000 gallons. We've had it for 7 years and have NEVER had a problem. I don't think we've ever even used the vacuum hose until this year. The pool navigator has always done the trick before. The pool store folks say to change the filter sand every few years-but I know lots of people who never have. We haven't. Maybe that's the problem. Whatever it is turns white when I shock the pool but always returns through the jets.
    Jul 2006
    I have an above ground pool and have been battling the same problem all season. I had something similar a few years ago and was told it was dead algae and to simply vacuum it to waste. We have done this over and over and when I turn the filtration back on in the morning the stuff reappears on the pool bottom within an hour. We have replaced the sand in the filter and thoroughly cleaned all the guts (laterals, etc.). What is this stuff and why won't it go away? Could the top part of my filter need to be replaced - the part where I can turn it to filter, waste, rinse, etc.?
    Someone, please help!
    My water is crystal clear.
    Unhappy Re: What is this residue and how do I get rid of it?
    I have vacuumed to waste and replaced water so many times it is getting way too expensive! I have shocked the pool (Super shocked!) with 2pounds / 10,000 gal (4 lbs) and added the initial dose of algaecide (again). I will vacuum to waste this afternoon (after 24 hours) IF i can see the bottom. I don't want to run this water throught the filter but how else can i get it to clear enough to see the bottom? The water was crystal clear before I shocked it but it was obvious there was stuff on the sides and the bottom. I brushed it up before I shocked. It puffed very easily-you didn't even have to touch it hardly. Just hold your foot 3 inches away and paddle and it poofs. There was no stuff on the bottom until I turned the filtration on a few days ago. We will change the pool filter sand as soon possible abut can't get to it for about 2 weeks. Now it is very cloudy. The chlorine level is very high - waaayyyy over 15 ppm. How high should the Cl level stay to fight mustard algae and for how long?????The stabilizer level is 80. Couldn't test for CYA-the test kit provides the tube but not instructions (its written on the side of the stabilizer test tube.) Couldn't order from this site because kits were discontinued. Thanks a bunch. I am very frustrated with the lack of true information on the websites, etc. They all want to sell you their product but tell you nothing. Also how high is too high for safe chlorine levels for adults to swim in the pool. How can the pool be usable during all this?
    South Central PA
    Quote Originally Posted by swimmy
    With a CYA level of 80, you need to be at 20 ppm of CL to even reach shock level. See this thread - http://www.poolforum.com/pf2/showthread.php?t=365
    We are finishing our fight against mustard algae and have been maintaining shock level for nearly a week now. You will need to do the same. Don't let it drop below 20 until the algae is gone. It will also help if you can vacuum to waste as the stuff dies and drops to the floor.
    IG 30,000 gal vinyl
    Cool Re: What is this residue and how do I get rid of it?
    Thank you so much! Will keep it that high for at least a week. Will adjust stabilizer also. The information passed to me by all has helped quite a bit. I'm determined to improve at this so I'll just keep working at it! Will check back in later! Have a great fourth!
  1. Slightly cloudy with brown residue at the bottom
    By proximo in forum Dealing with Algae & Slime
    Last Post: 07-12-2013, 11:22 AM
  2. white residue or scale in fiberglass pool
    By Poolhouse in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2013, 12:18 PM
  3. white fine residue on floor of pool
    By Bixpoolguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-13-2012, 07:21 PM
  4. White foamy residue on pools surface...
    By Beanns in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-06-2012, 12:02 AM
  5. White Film / residue floating on top of pool.
    By jimmurphy24 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-18-2006, 12:51 PM
