Thread: Still showing no cya
    tjcat is offline ** No working email address ** tjcat 0
    Coopersburg Pa
    Default Still showing no cya
    Hi I want to thank everyone for their great pool advice my new pool water has been crystal clear and clean since we opened it using the bleach borax method! However, I can't get the cya level up. I have a 19000 gallon 28 ft round pool and I added cya (about 3 lbs) but my level still reads zero. I did not add more because when I read another post, it said to cut the level recommended by 1/3 to 1/2 because you can only drain off the acid. I am doing the test according to the directions on the PS 234 kit, does anyone have any suggestions? Thanks
    duraleigh Guest
    Default Re: Still showing no cya
    CYA takes a few days to show up in the test. When did you put it in?
    According to the bleach (cya) calculator, 3 lbs. would only take you to 20 ppm. The cya test will not show really show any level below 20. Dave's question above is good - when did you add it?
  1. Pool pump showing a high psi
    By Wakkoguy in forum Pool Equipment & Operations
    Last Post: 07-18-2012, 12:54 AM
  2. No Chlorine showing up!!
    By Preston in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-28-2012, 07:13 PM
  3. Chlorine Not Showing Up...
    By tommypenngotti in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2009, 05:20 PM
  4. CYA not showing yet.
    By les_smith in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2006, 11:16 AM
  5. Help! 911 - algae showing up
    By sw_stupid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2006, 08:44 PM
