First off....great site!!! I have been reading the forums for a few days now and have learned a bunch. I only have the Intex 18' x 48" but am planning on getting a nice AG some time down the road. Any way...here are my numbers taken with the Taylor K-2006C.
PH - 7.0 - I added some Borax about 1 hour ago to raise this a little.
FC - 12 ppm - I have been adding more bleach each nite trying to get a good shock so I new this would be higher. I did not realize that my CYA was as high as it is. I was using the strips prior to the Taylor and they were not even close to accurate.
CC - .5 ppm
CYA - 75
Alk - 160
Temp - 88
I am in Texas and the pool is in direct sun light.
My water is fairly clear, but I do see some small particles at night which I would love to get rid of.
I have read about putting nylon stocking on the skimmer to catch the smaller particles, but do not know if this does help. I am currently running my pump 24/7 while adding bleach each night and brushing the pool daily. I now know I need to raise my Cholorine level much higher to get the correct shock level for my CYA (per the calcualtor)
Any suggestions on what I could do to clear things up would be appreciated.
Also...should I consider lowering my CYA level or stick with the 75?
Thanks for your help.
