Thread: Calcium and heaters
    NY
    Default Calcium and heaters
    I thought I read somewhere that if you have a heater you should have a calcium reading of at least 200 in a vinyl pool and more in a plaster/gunite/concrete pool. Is that true and if so, what effect does the calcium have on a heater?
    Thanks!
    Default Re: Calcium and heaters
    Is that 60 or above? Is there a limit?
    Ft Lauderdale, Fl
    You should look at your overall water balance (saturation index). Low calcium will contribute to a corrosive water condition (in conjunction with low alkalinity and/or low pH levels.) In addition, it is desired to be a little on the scaling side rather than corrosive side as this will allow some calcium to coat the inside of the heat exchanger, which may reduce some efficiency but it will offer a little protection against heat exchanger corrosion damage. I don't deal with vinyl liner pools that much but I do deal with heater issues occasionally and alot of water chemistry problems.
    Sean Assam
  1. Calcium and pool heaters
    By Spensar in forum The China Shop
    Last Post: 05-27-2013, 09:55 PM
  2. SWG and Heaters
    By les_garten in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:45 AM
  3. Using two heaters
    By beebepooler in forum Pool Equipment & Operations
    Last Post: 07-19-2011, 01:18 AM
  4. Gas Heaters - Which One?
    By michelle73 in forum In-Ground Pool Construction and Repair
    Last Post: 08-07-2006, 09:45 AM
  5. How much calcium in calcium-based shock?
    By cleancloths in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2006, 04:58 PM
