Thread: Hazy water - how much shock?
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Thumbs down Hazy water - how much shock?
    10000 gal IG vinyl liner, sand filter BBB
    FC 19.5 raised it to this level this morning
    previously FC 9
    CC <.5
    TC 20 ish
    pH 7.5
    TA 130
    CA 140
    CYA 90
    Temp 84
    My question is... have I raised the FC high enough for shocking w/ a CYA of 90? The haze is improving a bit, but I want to make sure I get rid of whatever is causing it (algae or whatever).
    By the way, this is the first time my water has NOT been crystal clear in over 1 Year (when I converted to BBB).
    Looking at Ben's Best Guess chart, FC of 20 might be high enough, but I'm almost at CYA 100 which suggests shocking to FC 25. What do you guys think I need to do?
    drband's Avatar
    Gainesville, GA
    Default Re: Hazy water - how much shock?
    Down to FC 4 a few days ago.
    I also recently switched my pump to a timer instead of 24/7. I run it 4-5 hours, twice per day.
    drband's Avatar
    Gainesville, GA
    Talking Re: Hazy water - how much shock?
    Seems to be clearing up nicely this morning. FC of 20 must be about right to shock (like the best guess chart says!)
    Also confirms to me that my CYA IS right about 90. That test is rather subjective, but I think I understand how to read it a little better now.
    Yeah, keep the FC at 20...check 3x/day to keep it there. It should keep clearing
    And follow the usual ritual until it's clean:
    1) filter 24/7
    2) Brush daily
    3) Vacuum daily to waste.
    Amazing how that "BestGuess" table works, isn't it!
  1. my pool water is hazy what must I do ??
    By jesse in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-27-2012, 02:26 PM
  2. Hazy water
    By Dan Heinrikson in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-31-2012, 10:00 PM
  3. Water balanced, new filter, still hazy...
    By sunlove in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2012, 12:08 AM
  4. Hazy water
    By DennyB65 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-03-2008, 07:10 PM
